MartinV56 867 Publicado March 21, 2012 at 00:56 Autor Share Publicado March 21, 2012 at 00:56 (editado) Zanden 9600http://www.zandenaudio.com/Product/m9600.html Editado July 13, 2016 at 02:33 por MartinV56 Citar "What this country needs is a good 5 watt amplifier." - Paul Klipsch Enlace al comentario Compartir en otros sitios More sharing options...
MartinV56 867 Publicado March 21, 2012 at 01:02 Autor Share Publicado March 21, 2012 at 01:02 (editado) http://www.venture-a...t.aspx?catid=71 Editado July 13, 2016 at 02:33 por MartinV56 Citar "What this country needs is a good 5 watt amplifier." - Paul Klipsch Enlace al comentario Compartir en otros sitios More sharing options...
MartinV56 867 Publicado March 21, 2012 at 01:09 Autor Share Publicado March 21, 2012 at 01:09 (editado) Yoshiba Onkyohttp://www.yoshiba-audio.com/ Editado July 13, 2016 at 02:33 por MartinV56 Citar "What this country needs is a good 5 watt amplifier." - Paul Klipsch Enlace al comentario Compartir en otros sitios More sharing options...
MartinV56 867 Publicado March 21, 2012 at 19:12 Autor Share Publicado March 21, 2012 at 19:12 (editado) http://www.hino-audio.co.jp/main_set.htmlhttp://www.hino-audi...SHOP/amp24.html Editado July 13, 2016 at 02:33 por MartinV56 Citar "What this country needs is a good 5 watt amplifier." - Paul Klipsch Enlace al comentario Compartir en otros sitios More sharing options...
MartinV56 867 Publicado March 21, 2012 at 22:00 Autor Share Publicado March 21, 2012 at 22:00 (editado) Lagarto san hizo un nuevo 2A3/45/71A set amphttp://www.single-en...com/new-diy.htm Editado July 13, 2016 at 02:33 por MartinV56 Citar "What this country needs is a good 5 watt amplifier." - Paul Klipsch Enlace al comentario Compartir en otros sitios More sharing options...
MartinV56 867 Publicado March 22, 2012 at 18:11 Autor Share Publicado March 22, 2012 at 18:11 (editado) http://www.haglabs.com/pa10.html Editado July 13, 2016 at 02:33 por MartinV56 Citar "What this country needs is a good 5 watt amplifier." - Paul Klipsch Enlace al comentario Compartir en otros sitios More sharing options...
MartinV56 867 Publicado March 22, 2012 at 18:34 Autor Share Publicado March 22, 2012 at 18:34 (editado) http://www.mastersou...1_ing/index.htmhttp://www.mastersou...g/integrati.htm Editado July 13, 2016 at 02:33 por MartinV56 Citar "What this country needs is a good 5 watt amplifier." - Paul Klipsch Enlace al comentario Compartir en otros sitios More sharing options...
MartinV56 867 Publicado March 22, 2012 at 21:14 Autor Share Publicado March 22, 2012 at 21:14 (editado) Ahora la pregunta es: Single ended o Push Pull?http://homepage.mac....-v-PP-Part1.pdfhttp://homepage.mac....-v-PP-Part2.pdfhttp://www.aikenamps...SingleEnded.htm Push Pull:La configuración push-pull se utiliza como etapa de salida de ciertos tipos de amplificadores de potencia. Por la misma razón, estos amplificadores se denominan amplificadores push-pull. En este tipo de amplificadores, los dos dispositivos, o grupos de dispositivos, de salida (transistores o tubos) operan en contrafase, lo cual significa que sus señales de control están desfasadas 180º. Las dos salidas en contrafase se conectan a la carga de tal forma que las componentesde señal se suman mientras que las componentes de distorsión debidas a la no linealidad de los dispositivos de salida se restan. Si la no linealidad de ambos dispositivos de salida es similar, la distorsión se reduce considerablemente. Los circuitos puh-pull simétricos deben cancelar las armónicas de orden par (f2, f4, f6) y favorecer las armónicas de orden impar (f1, f3, f5) cuando se manejan en el rango no lineal. Un amplificador push-pull produce menos distorsión que un amplificador de terminación simple, single ended. Esto permite que un amplificador clase A o clase AB tenga mucho menos distorsión para la misma potencia que sus versiones de terminación simple. En general, los amplificadores clase AB y clase B disipan mucha menos potencia para la misma salida que los amplificadores clase A y la distorsión se puede mantener muy baja mediante la aplicación de grandes cantidades de realimentación negativa. Una configuración especial de salidas push-pull análogas son las que utilizan válvulas o tubos de vacío. En este caso se utilizan dos tubos, o grupos de tubos, idénticos con sus rejillas de control gobernadas en contrafase. Estos tubos manejan la corriente a través de las dos mitades del devanado primario de un transformador con derivación central de salida, de modo que las corrientes de señal se suman, mientras que las señales de distorsión debidas a las curvas características no lineales del tubo se cancelan. Los amplificadores con salidas push-pull de tubos fueron diseñados mucho antes del desarrollo de los dispositivos electrónicos de estado sólido.Valga la anterior introducción para darle cabida en este post a los amplificadores valvulares push pull de actual producción. Si estás interesado en los valvulares de la época dorada del tubo te invito a visitar:http://www.hifichile...ge/page__st__60 Editado July 13, 2016 at 02:33 por MartinV56 Citar "What this country needs is a good 5 watt amplifier." - Paul Klipsch Enlace al comentario Compartir en otros sitios More sharing options...
MartinV56 867 Publicado March 22, 2012 at 21:29 Autor Share Publicado March 22, 2012 at 21:29 (editado) http://www.fat-man.co.uk/ Editado July 13, 2016 at 02:34 por MartinV56 Citar "What this country needs is a good 5 watt amplifier." - Paul Klipsch Enlace al comentario Compartir en otros sitios More sharing options...
MartinV56 867 Publicado March 22, 2012 at 21:42 Autor Share Publicado March 22, 2012 at 21:42 (editado) http://lebenhifi.com/products/index.htmlhttp://lebenhifi.com/products/cs300xs.html Editado July 13, 2016 at 02:34 por MartinV56 Citar "What this country needs is a good 5 watt amplifier." - Paul Klipsch Enlace al comentario Compartir en otros sitios More sharing options...
MartinV56 867 Publicado March 22, 2012 at 21:53 Autor Share Publicado March 22, 2012 at 21:53 (editado) http://www.mcintoshlabs.com/us/Products/pages/ProductDetails.aspx?CatId=Amplifiers&ProductId=MC275LimitedEdition Editado July 13, 2016 at 02:34 por MartinV56 Citar "What this country needs is a good 5 watt amplifier." - Paul Klipsch Enlace al comentario Compartir en otros sitios More sharing options...
MartinV56 867 Publicado March 22, 2012 at 22:02 Autor Share Publicado March 22, 2012 at 22:02 (editado) http://www.vac-amps.com/auriclepwr.htm Replica por Vac del legendario Marantz 8B Editado July 13, 2016 at 02:34 por MartinV56 Citar "What this country needs is a good 5 watt amplifier." - Paul Klipsch Enlace al comentario Compartir en otros sitios More sharing options...
MartinV56 867 Publicado March 22, 2012 at 22:12 Autor Share Publicado March 22, 2012 at 22:12 [img]http://img708.imageshack.us/img708/305/net070802.jpg[/img] [url="http://triodeelectronics.com/st70buildkit.html"]http://triodeelectronics.com/st70buildkit.html[/url] Otra leyenda valvular, ofrecen una nueva versión en kit [img]http://img861.imageshack.us/img861/2272/triodeel220432635538.jpg[/img] Citar "What this country needs is a good 5 watt amplifier." - Paul Klipsch Enlace al comentario Compartir en otros sitios More sharing options...
MartinV56 867 Publicado March 22, 2012 at 22:50 Autor Share Publicado March 22, 2012 at 22:50 (editado) http://www.grommeshifi.com/ Editado July 13, 2016 at 02:34 por MartinV56 Citar "What this country needs is a good 5 watt amplifier." - Paul Klipsch Enlace al comentario Compartir en otros sitios More sharing options...
MartinV56 867 Publicado March 28, 2012 at 19:22 Autor Share Publicado March 28, 2012 at 19:22 (editado) SE 808http://www.voxativ.com/eng/ Editado July 13, 2016 at 02:34 por MartinV56 Citar "What this country needs is a good 5 watt amplifier." - Paul Klipsch Enlace al comentario Compartir en otros sitios More sharing options...
MartinV56 867 Publicado March 28, 2012 at 20:11 Autor Share Publicado March 28, 2012 at 20:11 (editado) http://www.museumofm.../airport/case-2 y así empezó la alta fidelidad, allá por los años 20 la era del Jazz o Jazz age en palabras de Scott Fitzgerald Editado July 13, 2016 at 02:34 por MartinV56 Citar "What this country needs is a good 5 watt amplifier." - Paul Klipsch Enlace al comentario Compartir en otros sitios More sharing options...
MartinV56 867 Publicado March 28, 2012 at 20:54 Autor Share Publicado March 28, 2012 at 20:54 (editado) http://www.shinkukan-jidai.com/additional_radio_pages/page_3.html Editado July 13, 2016 at 02:34 por MartinV56 Citar "What this country needs is a good 5 watt amplifier." - Paul Klipsch Enlace al comentario Compartir en otros sitios More sharing options...
MartinV56 867 Publicado March 28, 2012 at 20:58 Autor Share Publicado March 28, 2012 at 20:58 (editado) http://www.hifichile.cl/index.php?/topic/1005-loftinwhite-amplifier/ Editado July 13, 2016 at 02:35 por MartinV56 Citar "What this country needs is a good 5 watt amplifier." - Paul Klipsch Enlace al comentario Compartir en otros sitios More sharing options...
MartinV56 867 Publicado March 29, 2012 at 23:33 Autor Share Publicado March 29, 2012 at 23:33 (editado) http://www.balanced.com/ Editado July 13, 2016 at 02:35 por MartinV56 Citar "What this country needs is a good 5 watt amplifier." - Paul Klipsch Enlace al comentario Compartir en otros sitios More sharing options...
MartinV56 867 Publicado March 29, 2012 at 23:38 Autor Share Publicado March 29, 2012 at 23:38 (editado) http://www.audioresearch.com/Reference750.htmlhttp://www.audioresearch.com/Reference750.pdf Editado July 13, 2016 at 02:35 por MartinV56 Citar "What this country needs is a good 5 watt amplifier." - Paul Klipsch Enlace al comentario Compartir en otros sitios More sharing options...
