Jaiume Ramirez 0 Publicado October 2, 2022 at 22:25 Share Publicado October 2, 2022 at 22:25 Hola Amigos Necesiti¿o de su ayuda, tengo un problema con mi Receiver Yamaha RX-V6A, en el panel Led aparace la siguiente leyenda "DECODER OFF". El receiver no tiene sonido. Agradeceria que me ayudaran, gracias Citar Enlace al comentario Compartir en otros sitios More sharing options...
juliogh 59 Publicado October 4, 2022 at 19:09 Share Publicado October 4, 2022 at 19:09 Esta es una de las respuestas que aparece si lo buscas en google, si no sábes Inglés puedes aplicar google translator: The front panel display of the receiver reads DECODER OFF. What does this mean and how can I change it? Back to the List Last Update: 5/12/2011 The DECODER OFF message is purely an information message. It can mean one of two things - a two channel source is input or there is no input. In either case the receiver would not need to turn on a decoder to play sound. You can toggle this informational display by pressing the INFO button on the front panel of the receiver or on the remote control (depending on your model receiver) – you will have three choices: DSP Program, Audio Decoder, and Input. The INFO button basically tells you the status of the receiver. You cannot "turn the decoder on" - the receiver is designed to automatically select and activate (turn on) the proper decoder based on the input signal from the source (DVD player, BD player, cable box, etc.). For example, if your DVD player sends a Dolby Digital signal to the receiver the receiver will see that and automatically activate the Dolby Digital decoder. If the decoder off message is accompanied by a loss in picture and/or sound, we would suggest double checking all your connecting cables between the source component and receiver. Just one bent or damaged cable or connector can cause a loss in picture and/or sound. Ojalá solo sea que no detecta nada en la entrada a decodificar y no sea que tengas una puerta mala Ej. alguna sino todas las puertas HDMI. Citar Enlace al comentario Compartir en otros sitios More sharing options...
Jaiume Ramirez 0 Publicado October 5, 2022 at 19:20 Autor Share Publicado October 5, 2022 at 19:20 Ok, gracias por tu respuesta, revisare los cables. Saludos Citar Enlace al comentario Compartir en otros sitios More sharing options...
