peliculero 7 Publicado August 26, 2011 at 13:57 Share Publicado August 26, 2011 at 13:57 MUchachones, desde hace unos días las graciones tanto de dvd,como los mkv grabados en discos dvd me marcan error, e gastado ene discos. aparece el siguente detalle: 4C82-0010-8011-0000-9704-3694-1599 Windows XP 5.1 IA32 WinAspi: - ahead WinASPI: File 'C:\Archivos de programa\Nero\Nero 7\Core\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 02/11/2004 12:54:32 p.m. NT-SPTI used Nero API version: 7.0.1.2 Using interface version: 6.3.1.4 Installed in: C:\Archivos de programa\Nero\Nero 7\Core\ Application: ahead\Nero - Burning Rom Internal Version: 7, 0, 1, 2 Recorder: <HL-DT-ST DVD-RAM GSA-H22N>Version: 1.00 - HA 1 TA 0 - 7.0.1.2 Adapter driver: <IDE> HA 1 Drive buffer : 2048kB Bus Type : via Inquiry data (1) -> ATAPI, detected: ? Connected to MMC as unknown drive with class-nr : 1 Drive is autodetected - recorder class: Std. MMC recorder === Scsi-Device-Map === DiskPeripheral : WDC WD400BB-00JHC0 atapi Port 0 ID 0 DMA: On DiskPeripheral : Maxtor 6B200R0 atapi Port 0 ID 1 DMA: On CdRomPeripheral : HL-DT-ST DVD-RAM GSA-H22N atapi Port 1 ID 0 DMA: On CdRomPeripheral : HL-DT-ST DVDRAM GSA-4167B atapi Port 1 ID 1 DMA: On === CDRom-Device-Map === HL-DT-ST DVD-RAM GSA-H22N E: CDRom0 HL-DT-ST DVDRAM GSA-4167B F: CDRom1 ======================= AutoRun : 1 Excluded drive IDs: WriteBufferSize: 83886080 (0) Byte ShowDrvBufStat : 0 BUFE : 0 Physical memory : 767MB (785712kB) Free physical memory: 322MB (329988kB) Memory in use : 58 % Uncached PFiles: 0x0 Use Inquiry : 1 Global Bus Type: default (0) Check supported media : Disabled (0) 26.8.2011 NeroAPI 10:52:16 a.m. #1 Phase 112 File APIProgress.cpp, Line 278 DVD-Video files reallocation started 10:52:16 a.m. #2 Phase 114 File APIProgress.cpp, Line 278 DVD-Video files reallocation completed (no file modified) 10:52:16 a.m. #3 Phase 111 File APIProgress.cpp, Line 278 DVD-Video files sorted 10:52:17 a.m. #4 Text 0 File ThreadedTransfer.cpp, Line 496 Tried to get 262144 KB of memory 10:52:17 a.m. #5 TRANSFER -5 File ThreadedTransfer.cpp, Line 497 Error: not enough memory 10:52:17 a.m. #6 Text 0 File ThreadedTransfer.cpp, Line 525 ReadBuffer-Pipe got 131072KB of Memory - requested 262144KB of Memory 10:52:17 a.m. #7 Text 0 File Reader.cpp, Line 124 Reader running 10:52:17 a.m. #8 Text 0 File Writer.cpp, Line 113 Writer E: HL-DT-ST DVD-RAM GSA-H22N running 10:52:17 a.m. #9 Text 0 File AudioCompilationImpl.cpp, Line 842 DRM: StartDrmRecording(RealRec:1, ImageRec:0, Copies:1) DRM: Beginning burn process. 10:52:17 a.m. #10 ISO9660GEN -11 File Geniso.cpp, Line 3312 First writeable address = 0 (0x00000000) 10:52:17 a.m. #11 ISO9660GEN -11 File Geniso.cpp, Line 3312 First writeable address = 0 (0x00000000) 10:52:17 a.m. #12 Text 0 File Burncd.cpp, Line 3302 Turn on Disc-At-Once, using DVD media 10:53:02 a.m. #13 Text 0 File DlgWaitCD.cpp, Line 279 Last possible write address on media: 2295103 (510:01.28, 4482MB) Last address to be written: 2286127 (508:01.52, 4465MB) 10:53:02 a.m. #14 Text 0 File DlgWaitCD.cpp, Line 291 Write in overburning mode: NO 10:53:02 a.m. #15 Text 0 File DlgWaitCD.cpp, Line 2578 Recorder: HL-DT-ST DVD-RAM GSA-H22N, Media type: DVD+R Disc Manufacturer ID: CMC MAG, Media Type ID: M01, Product revision number: 0 Disc Application Code: 0, Extended Information Indicators: 7 10:53:02 a.m. #16 Text 0 File DlgWaitCD.cpp, Line 458 >>> Protocol of DlgWaitCD activities: <<< ========================================= Insert empty disc to write to. (Medium in drive: unknown. Medium required by compilation: DVD+R/RW, DVD-R/RW, DVD-RAM, DVD-R DL, DVD+R DL.) 10:53:02 a.m. #17 Text 0 File ThreadedTransferInterface.cpp, Line 847 Setup items (after recorder preparation) 0: TRM_DATA_MODE1 () 2 indices, index0 (150) not provided original disc pos #0 + 2286128 (2286128) = #2286128/508:1.53 relocatable, disc pos for caching/writing not required/ required, no patch infos -> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2286128 blocks [E: HL-DT-ST DVD-RAM GSA-H22N] -------------------------------------------------------------- 10:53:02 a.m. #18 Text 0 File ThreadedTransferInterface.cpp, Line 1059 Prepare recorder [E: HL-DT-ST DVD-RAM GSA-H22N] for write in CUE-sheet-DAO DAO infos: ========== MCN: "" TOCType: 0x00; Session Closed, disc fixated Tracks 1 to 1: 1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4681990144, ISRC "" DAO layout: =========== __Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep__________ 0 | lead-in | 0 | 0x41 | 0x00 0 | 1 | 0 | 0x41 | 0x00 0 | 1 | 1 | 0x41 | 0x00 2286128 | lead-out | 1 | 0x41 | 0x00 10:53:02 a.m. #19 Text 0 File SCSIPassThrough.cpp, Line 36 SPTILockVolume - completed successfully for FCTL_LOCK_VOLUME 10:53:02 a.m. #20 Phase 24 File APIProgress.cpp, Line 278 Caching of files started 10:53:02 a.m. #21 Text 0 File Burncd.cpp, Line 4132 Cache writing successful. 10:53:02 a.m. #22 Phase 25 File APIProgress.cpp, Line 278 Caching of files completed 10:53:02 a.m. #23 Phase 36 File APIProgress.cpp, Line 278 Burn process started at 16x (22,160 KB/s) 10:53:02 a.m. #24 Text 0 File ThreadedTransferInterface.cpp, Line 2685 Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0 10:53:02 a.m. #25 Text 0 File Cdrdrv.cpp, Line 8411 ---- DVD Structure: Physical Format Information (00h) ---- Layer: 0, Address: 0 (0 ), AGID: 0; Length: 2050 Book Type: DVD+R (10), Part Version: 1.0x (1) Disc Size: 120 mm, Maximum Rate: <not specified> (F ) Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable Linear Density: 0,267 um/bit, Track Density: 0,74 um/track Starting Physical Sector Number of Data Area: 30000 (DVD-ROM, DVD-R/-RW, DVD+R/+RW) End Physical Sector Number of Data Area: 26053F End Sector Number in Layer 0: 0 (LBN: FFFD0000 , 4193920 MB) Data in Burst Cutting Area (BCA) does not exist Disc Application Code: 0 / 0 Extended Information indicators: 7 Disc Manufacturer ID: CMC.MAG. Media type ID: M01 Product revision number: 0 Number of Physical format information bytes in use in ADIP up to byte 63: 56 Media Specific [16..63]: 00 00 07 43 4D 43 20 4D - 41 47 00 4D 30 31 00 38 ...CMC.MAG.M01.8 23 54 37 18 00 3E 6E 00 - 70 62 15 15 0B 0B 08 08 #T7..>n.pb...... 01 19 1B 0B 0B 0E 0F 01 - 00 00 00 00 00 00 00 00 ................ 10:53:02 a.m. #26 Text 0 File DVDR.cpp, Line 5400 Drive: HL-DT-ST DVD-RAM GSA-H22N Book Type request [LG]: DVD-ROM Changing the Book Type was finished successfully, return code 0 10:53:02 a.m. #27 CDR -1211 File DVDR.cpp, Line 5321 Book Type set to: DVD-ROM 10:53:02 a.m. #28 Text 0 File DVDPlusRW.cpp, Line 666 Start write address at LBA 0 DVD high compatibility mode: Yes 10:53:19 a.m. #29 SPTI -1135 File SCSIPassThrough.cpp, Line 323 E: CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1135) Sense Key: 0x03 (KEY_MEDIUM_ERROR) Sense Code: 0x0C Sense Qual: 0x80 CDB Data: 0x2A 00 00 00 00 00 00 00 20 00 00 00 Sense Area: 0x70 00 03 00 00 00 00 0E 00 00 00 00 0C 80 Buffer x01000000: Len x10000 0x00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 10:53:19 a.m. #30 CDR -1135 File Writer.cpp, Line 302 Write error E: HL-DT-ST DVD-RAM GSA-H22N 10:53:19 a.m. #31 Text 0 File ThreadedTransfer.cpp, Line 228 all writers idle, stopping conversion 10:53:19 a.m. #32 Text 0 File ThreadedTransfer.cpp, Line 222 conversion idle, stopping reader 10:53:19 a.m. #33 Phase 127 File APIProgress.cpp, Line 278 Generating DVD high compatibility borders 10:53:19 a.m. #34 Phase 129 File APIProgress.cpp, Line 278 Generating DVD borders completed successfully 10:53:19 a.m. #35 Phase 38 File APIProgress.cpp, Line 278 Burn process failed at 16x (22,160 KB/s) 10:53:19 a.m. #36 Text 0 File AudioCompilationImpl.cpp, Line 867 DRM: DRM burn session terminated. 10:53:19 a.m. #37 Text 0 File AudioCompilationImpl.cpp, Line 896 DRM: Closing entire DRM handling. Bye. Existing drivers: Registry Keys: HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option) Que cresta puede ser... Citar Mi sala por acá: http://www.blu-ray.c...mber=peliculero Mis Blu-Ray por acà: http://www.blu-ray.com/community/collection.php?u=67172 Mi canal de videos : https://www.youtube.com/user/SuperPeliculero?feature=mhee "el cine es un invento sin futuro".Louis Lumiére 1895. Enlace al comentario Compartir en otros sitios More sharing options...
ian curtis 343 Publicado August 26, 2011 at 14:06 Share Publicado August 26, 2011 at 14:06 Como no vas a saber Esta clarito!!! jejeje Citar "No satisface el saber mucho, sino el sentir y gustar internamente de las cosas" San Ignacio de Loyola ¿Y tu hermana? Enlace al comentario Compartir en otros sitios More sharing options...
peliculero 7 Publicado August 26, 2011 at 14:12 Autor Share Publicado August 26, 2011 at 14:12 [quote name='ian curtis' date='26 August 2011 - 11:06 AM' timestamp='1314367578' post='82057'] Como no vas a saber Esta clarito!!! jejeje [/quote] puta da la respuesta poH, pa mi es chino¡¡ Citar Mi sala por acá: http://www.blu-ray.c...mber=peliculero Mis Blu-Ray por acà: http://www.blu-ray.com/community/collection.php?u=67172 Mi canal de videos : https://www.youtube.com/user/SuperPeliculero?feature=mhee "el cine es un invento sin futuro".Louis Lumiére 1895. Enlace al comentario Compartir en otros sitios More sharing options...
ElEdu 4 Publicado August 26, 2011 at 14:18 Share Publicado August 26, 2011 at 14:18 No soy capi de interpretar bien el informe que pusiste, parece que la grabación se interrumpe (empieza pero no concluye). Trata de contarnos más detalles: - ¿cambiaste marca/tipo de DVD que usas para grabar? (hay DVD-R, DVD+R, etc) Yo tuve problemas con discos Zykon DVD-R, claro que la grabación terminaba pero quedaba pifiada. - ¿hiciste algún cambio de versión de Nero? - ¿Has probado con otra aplicación para grabar? Citar Stereo: Eastsound CD-E5 / JVC L-F66 con BHL phono pre (DIY) / servidor Raspberry Pi con Big Ben DAC (DIY) + Jungson JA-88D + Parlantes Troels Gravesen TJL-2W (DIY). Portátil: iPod Video 60G con rockbox + HiFiMAN RE-400 Fonos grandes: Sennheiser HD-600 con amplificador Objective2 Enlace al comentario Compartir en otros sitios More sharing options...
Patagonia 739 Publicado August 26, 2011 at 14:19 Share Publicado August 26, 2011 at 14:19 (editado) Yo no le pego al tema pero a veces algunas marcas de discos tienen problemas con algunos grabadores, no habrás cambiado de marca? saludos Editado August 26, 2011 at 14:19 por Patagonia Citar Enlace al comentario Compartir en otros sitios More sharing options...
peliculero 7 Publicado August 26, 2011 at 14:23 Autor Share Publicado August 26, 2011 at 14:23 chuta son discos dvd+r imation, pero en el pc de mi pega no me dieron atados. usaba marca @ antes y sin atados...gracias son unos caballeros no como otro¡¡ Citar Mi sala por acá: http://www.blu-ray.c...mber=peliculero Mis Blu-Ray por acà: http://www.blu-ray.com/community/collection.php?u=67172 Mi canal de videos : https://www.youtube.com/user/SuperPeliculero?feature=mhee "el cine es un invento sin futuro".Louis Lumiére 1895. Enlace al comentario Compartir en otros sitios More sharing options...
ian curtis 343 Publicado August 26, 2011 at 14:24 Share Publicado August 26, 2011 at 14:24 [quote name='peliculero' date='26 August 2011 - 10:12 AM' timestamp='1314367973' post='82062'] [quote name='ian curtis' date='26 August 2011 - 11:06 AM' timestamp='1314367578' post='82057'] Como no vas a saber Esta clarito!!! jejeje [/quote] puta da la respuesta poH, pa mi es chino¡¡ [/quote] [quote name='peliculero' date='26 August 2011 - 09:57 AM' timestamp='1314367032' post='82048'] DAO layout: =========== __Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep__________ 0 | lead-in | 0 | 0x41 | 0x00 0 | 1 | 0 | 0x41 | 0x00 0 | 1 | 1 | 0x41 | 0x00 2286128 | lead-out | 1 | 0x41 | 0x00 00 00 07 43 4D 43 20 4D - 41 47 00 4D 30 31 00 38 ...CMC.MAG.M01.8 23 54 37 18 00 3E 6E 00 - 70 62 15 15 0B 0B 08 08 #T7..>n.pb...... 01 19 1B 0B 0B 0E 0F 01 - 00 00 00 00 00 00 00 00 ................ 10:53:19 a.m. #29 SPTI -1135 File SCSIPassThrough.cpp, Line 323 E: CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1135) Sense Key: 0x03 (KEY_MEDIUM_ERROR) Sense Code: 0x0C Sense Qual: 0x80 CDB Data: 0x2A 00 00 00 00 00 00 00 20 00 00 00 Sense Area: 0x70 00 03 00 00 00 00 0E 00 00 00 00 0C 80 Buffer x01000000: Len x10000 0x00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 [/quote] Ahi esta la respuesta po!, como cresta no la habias visto!!?!?!? jajaja Citar "No satisface el saber mucho, sino el sentir y gustar internamente de las cosas" San Ignacio de Loyola ¿Y tu hermana? Enlace al comentario Compartir en otros sitios More sharing options...
Juanzuniga 1.075 Publicado August 26, 2011 at 14:30 Share Publicado August 26, 2011 at 14:30 (editado) Y lo otro (no se si ya lo haces de esa manera) es grabar siempre a la menor velocidad de escritura... se demora más, pero es mas confiable! Pienso que aquí puede estar la clave: 10:52:17 a.m. #5 TRANSFER -5 File ThreadedTransfer.cpp, Line 497 Error: [b]not enough memory[/b] Editado August 26, 2011 at 14:33 por Juanzuniga Citar Vndo tclado barato, qu l falta una tcla Nakamichi Amplifier1, Cassettedeck2, ST-3s Tuner, Unison Research Unico CD, Technics SH-GE90 DSP, Technics SL-D33 Turntable, EMOTIVA Stealth DC-1 DAC, JBL model 4312 Control Monitor Enlace al comentario Compartir en otros sitios More sharing options...
UPset64 329 Publicado August 26, 2011 at 14:50 Share Publicado August 26, 2011 at 14:50 (editado) Peliculero, Menos mal que no me colgué de la respuesta de Ian pa palanquearte, te habrías enojado ...pero es la talla-respuesta lógica. Hay que saber de informática para descifrar lo que enviaste, yo me dí cuenta de que ese poncho me quedaba grande hace raaato. Cuando yo hago respaldo, me aseguro de que: - No hay ningún otro programa ejecutándose -ni protector de pantalla ni antivirus ni ná - No uso discos muy baratos -por decirlo de alguna manera. Incluso hace poco a un disco 3M Imation, se le despegó la tela metálica...y perdi interpretaciones de Arrau de conciertos de Chopin - Uso la velocidad mínima que el grabador LG me permite. Aunque pase la prueba a 16x, lo fuerzo a 2x (lo mínimo hoy ) Suerte, Editado August 26, 2011 at 14:51 por UPset64 Citar Enlace al comentario Compartir en otros sitios More sharing options...
peliculero 7 Publicado August 26, 2011 at 15:05 Autor Share Publicado August 26, 2011 at 15:05 si siempre grabo x 4 y lo de la memoria no lo entiendo pues recién prendido el pc trate de hacer esa grabacion, estaba descansado el tarro. Citar Mi sala por acá: http://www.blu-ray.c...mber=peliculero Mis Blu-Ray por acà: http://www.blu-ray.com/community/collection.php?u=67172 Mi canal de videos : https://www.youtube.com/user/SuperPeliculero?feature=mhee "el cine es un invento sin futuro".Louis Lumiére 1895. Enlace al comentario Compartir en otros sitios More sharing options...
Biker 98 Publicado August 26, 2011 at 15:21 Share Publicado August 26, 2011 at 15:21 Eso le pasa por andar pirateando películas... vé que no el crimen no paga? Citar Si tu woofer no te sacude las vísceras hasta hacerte mear sangre... pues no es un woofer. Enlace al comentario Compartir en otros sitios More sharing options...
UPset64 329 Publicado August 26, 2011 at 15:53 Share Publicado August 26, 2011 at 15:53 ¿Tu PC está "higienizado"? Quiero decir, ¿Le corres regularmente el desfragmentador, está actualizado? ¿Sólo tienes problemas con ese programa, o anda cojeando heavy en otras aplicaciones -se corrompe, etc.? Yo creo que Fabian se maneja en esto... Citar Enlace al comentario Compartir en otros sitios More sharing options...
peliculero 7 Publicado August 26, 2011 at 16:09 Autor Share Publicado August 26, 2011 at 16:09 [quote name='UPset64' date='26 August 2011 - 12:53 PM' timestamp='1314374014' post='82091'] ¿Tu PC está "higienizado"? Quiero decir, ¿Le corres regularmente el desfragmentador, está actualizado? ¿Sólo tienes problemas con ese programa, o anda cojeando heavy en otras aplicaciones -se corrompe, etc.? Yo creo que Fabian se maneja en esto... [/quote] no ,solo me está pasando con el nero 7 ultra edition,lo desintale y lo volví a instalar. pero creo que son los discos. Citar Mi sala por acá: http://www.blu-ray.c...mber=peliculero Mis Blu-Ray por acà: http://www.blu-ray.com/community/collection.php?u=67172 Mi canal de videos : https://www.youtube.com/user/SuperPeliculero?feature=mhee "el cine es un invento sin futuro".Louis Lumiére 1895. Enlace al comentario Compartir en otros sitios More sharing options...
peliculero 7 Publicado August 26, 2011 at 16:10 Autor Share Publicado August 26, 2011 at 16:10 [quote name='Biker' date='26 August 2011 - 12:21 PM' timestamp='1314372093' post='82082'] Eso le pasa por andar pirateando películas... vé que no el crimen no paga? [/quote] chuta pasa esto y justo mañana que tengo feria. Citar Mi sala por acá: http://www.blu-ray.c...mber=peliculero Mis Blu-Ray por acà: http://www.blu-ray.com/community/collection.php?u=67172 Mi canal de videos : https://www.youtube.com/user/SuperPeliculero?feature=mhee "el cine es un invento sin futuro".Louis Lumiére 1895. Enlace al comentario Compartir en otros sitios More sharing options...
Patagonia 739 Publicado August 26, 2011 at 16:15 Share Publicado August 26, 2011 at 16:15 [quote name='peliculero' date='26 August 2011 - 12:10 PM' timestamp='1314375047' post='82094'] [quote name='Biker' date='26 August 2011 - 12:21 PM' timestamp='1314372093' post='82082'] Eso le pasa por andar pirateando películas... vé que no el crimen no paga? [/quote] chuta pasa esto y justo mañana que tengo feria. [/quote] Pero en la feria da lo mismo, entregas los discos vacíos...de ahí a que los prueben ya te arrancaste Citar Enlace al comentario Compartir en otros sitios More sharing options...
UPset64 329 Publicado August 26, 2011 at 17:07 Share Publicado August 26, 2011 at 17:07 [quote name='peliculero' date='26 August 2011 - 09:57 AM' timestamp='1314367032' post='82048'] 10:52:17 a.m. #4 Text 0 File ThreadedTransfer.cpp, Line 496 Tried to get 262144 KB of memory 10:52:17 a.m. #5 TRANSFER -5 File ThreadedTransfer.cpp, Line 497 Error: not enough memory 10:52:17 a.m. #6 Text 0 File ThreadedTransfer.cpp, Line 525 ReadBuffer-Pipe got 131072KB of Memory - requested 262144KB of Memory 10:52:17 a.m. #7 Text 0 File Reader.cpp, Line 124 Reader running ... 10:53:19 a.m. #34 Phase 129 File APIProgress.cpp, Line 278 Generating DVD borders completed successfully 10:53:19 a.m. #35 Phase 38 File APIProgress.cpp, Line 278 Burn process failed at 16x (22,160 KB/s) 10:53:19 a.m. #36 Text 0 File AudioCompilationImpl.cpp, Line 867 DRM: DRM burn session terminated. Que cresta puede ser... [/quote] Por lo poco que entiendo, hay algún problema de memoria que al final no es fatal, pero indica que la aplicación es musho pa la máquina. Después, la grabación falla al usar 16x. ¿Has ejecutado las pruebas del grabador, qué dan como resultado? Citar Enlace al comentario Compartir en otros sitios More sharing options...
UPset64 329 Publicado August 26, 2011 at 17:08 Share Publicado August 26, 2011 at 17:08 [quote name='Patagonia' date='26 August 2011 - 12:15 PM' timestamp='1314375322' post='82095'] [quote name='peliculero' date='26 August 2011 - 12:10 PM' timestamp='1314375047' post='82094'] [quote name='Biker' date='26 August 2011 - 12:21 PM' timestamp='1314372093' post='82082'] Eso le pasa por andar pirateando películas... vé que no el crimen no paga? [/quote] chuta pasa esto y justo mañana que tengo feria. [/quote] Pero en la feria da lo mismo, entregas los discos vacíos...de ahí a que los prueben ya te arrancaste [/quote] Citar Enlace al comentario Compartir en otros sitios More sharing options...
peliculero 7 Publicado August 26, 2011 at 17:10 Autor Share Publicado August 26, 2011 at 17:10 jajajaj guena¡¡ Citar Mi sala por acá: http://www.blu-ray.c...mber=peliculero Mis Blu-Ray por acà: http://www.blu-ray.com/community/collection.php?u=67172 Mi canal de videos : https://www.youtube.com/user/SuperPeliculero?feature=mhee "el cine es un invento sin futuro".Louis Lumiére 1895. Enlace al comentario Compartir en otros sitios More sharing options...
ZHAR 742 Publicado August 26, 2011 at 17:30 Share Publicado August 26, 2011 at 17:30 [quote name='UPset64' date='26 August 2011 - 11:53 AM' timestamp='1314374014' post='82091'] ¿Tu PC está "higienizado"? Quiero decir, ¿Le corres regularmente el desfragmentador, está actualizado? ¿Sólo tienes problemas con ese programa, o anda cojeando heavy en otras aplicaciones -se corrompe, etc.? Yo creo que Fabian se maneja en esto... [/quote] A todo esto... alguien ha sabido de Fabian... hace rato que no postea! Citar Bill Evans y su trío formado por Evans, el bajista Scott LaFaro y el baterista Paul Motian. Enlace al comentario Compartir en otros sitios More sharing options...
HÉROES 9 Publicado August 26, 2011 at 17:32 Share Publicado August 26, 2011 at 17:32 [quote name='Patagonia' date='26 August 2011 - 12:15 PM' timestamp='1314375322' post='82095'] [quote name='peliculero' date='26 August 2011 - 12:10 PM' timestamp='1314375047' post='82094'] [quote name='Biker' date='26 August 2011 - 12:21 PM' timestamp='1314372093' post='82082'] Eso le pasa por andar pirateando películas... vé que no el crimen no paga? [/quote] chuta pasa esto y justo mañana que tengo feria. [/quote] Pero en la feria da lo mismo, entregas los discos vacíos...de ahí a que los prueben ya te arrancaste [/quote] Jajajajajajaja, eso le pasó a un primo, según él venia con un estreno topisimo que era Spiderman, fuimos a ver la película y venia pelao el disco Citar Enlace al comentario Compartir en otros sitios More sharing options...
