Top Rated Record Cleaner Reviews
funkyto
A seguir soñando...
https://www.vinylvintage.net/record-cleaners/
Vinyl music gets a lot of flack for the crackly, popping noise people now associate with it. The fact is that vinyls actually don’t sound like that when they are properly maintained and aren’t damaged.
The popping you hear on old vinyls is actually the noise introduced by dust in the grooves. As I explained in my article on vinyl maintenance, the dust deforms the physical representation of the soundwave, causing artifacts.
While it’s always best to prevent or slow down the buildup of dust in your vinyl’s grooves in the first place, eventually you will have to clean them. In fact, it’s the records you love and listen to the most that will need cleaning first and most often.
Here I’ve put together some popular cleaning products that can help you get rid of the dust and restore the sound to what it’s supposed to be.
I’ve listed the ones that I think are the best at the top and the rest are in no particular order.
Top Pick:
Record Doctor
The pinnacle of record cleaning systems has always been the record vacuum system. The problem is that they are so expensive that only the very wealthiest enthusiasts can afford them, but the Record Doctor promises to give us some of that high-end performance for a relatively low price.
The main advantage of a machine like this is that it removes a lot of the risk of cleaning an LP. While there’s not that much that can go wrong with a traditional washer, you can still accidentally wet the label or otherwise scratch or harm the LP if you aren’t paying attention. The Record Doctor is supposed to not only take that minor risk away but also to perform better than a washer can.
Is it worth the money? Absolutely. Those who have one all agree on the cleaning performance. There are, however, some tradeoffs. The main issue seems to be that some units have motors that get a little hot with repeated use. Not everyone complains about it, but it’s easily solved by just waiting a bit should it happen.
I can’t stress how good a deal this is. I’m not going to expect perfection at this price point, but for us normal mortals this is probably the best deal out there.
Best Vinyl Washer:
Vinyl Styl Deep Groove Record Washer
This liquid washer system bills itself as an all-in-one solution that both washes and dries. The entire system is self-contained, which is a good thing since it can be a little messy to work with a fluid washer system.
It’s a really smart design. There’s a special clamp that makes sure that the label stays dry during washing, so you don’t have to be nervous about it.
It has a built-in drying rack; it also comes with filters to reuse the fluid, although personally it seems like quite a hassle and I’d probably just buy more fluid. If you are into recycling though, this is a neat feature.
Still, this is the most complete liquid washer system I’ve seen and it comes at a pretty decent price. In my opinion this is the best liquid washer for the money you can get.
Spin-Clean – Starter Kit Record Washer System MK2
Spin Clean is a name that comes up a lot when you search for Vinyl washers. It seems that while everyone forgot about the format for a few decades they were ready with the right thing at the right time.
You can also get this cleaner in a clear model, which is a limited edition. Personally I like this bright yellow. It has a very construction-utility feel to it. After all, a vinyl washer is not something that you put on display. It only gets taken out when you actually use it.
This is the starter kit, which comes with the basin unit, 4 oz. of fluid, a pair of brushes, and a pair of rollers. You also get two cloths to dry the record; with that you won’t cause damage to it or get it dirty again. Just don’t use them for anything else.
Spin Clean claims that the included fluid is enough to wash 400 records. This may or may not be a lot, depending on your collection and how hard you are on your vinyls. For most people this kit will be all you need for quite some time.
For most people who have bought one of these cleaners, the satisfaction level is quite high. You fill the basin, you spin the vinyl, and the dust gets taken off along with the fingerprints and grease.
Interestingly, some buyers say it starts to work better after a while; after things have bedded in, so to speak.
The only issue that I really have is the slightly high price. Other than that, it’s a pretty good deal.
Best Starter Pick:
RCA RD1006 Discwasher Vinyl Record Cleaning Kit
This cleaning kit is one of the best-selling items of its kind, if you look at the online rankings. One of the reasons is certainly the low asking price. For only a few dollars you can get started on your cleaning equipment. This is an especially good idea if you’ve recently started getting into vinyl and don’t have that many records yet.
The kit includes a microfiber pad and cleaning fluid. The point of both these items is to remove dust without causing additional scratches to the record. For the occasional cleaning this is enough for most people.
Since the price is so low and you can in theory use only this for maintenance cleaning, I can recommend this kit as a place to start things off.
Vinyl Vac Record Cleaner Vacuum Wand
The Record Doctor machine got my nod as the best deal for the rest of us, but there’s an even cheaper way – to vacuum instead of wash your vinyls. With this cheap little gizmo you only need to add the vacuum cleaner. With the help of an o-ring adapter to make sure it fits your vacuum snugly, you can clean the grooves of dust directly.
It comes with a felt washer to protect the labels and adapters to reduce the amount of suction, since not all vacuums are made equal. If you use this with a wet and dry vacuum you can add cleaning fluid to the record and vacuum it all away in one go.
There are quite a few skeptics who think this is too rough and simple, even if it is a good idea in principle. For all the negative sentiment some people express about this, the actual performance is reportedly pretty good. If you combine this with your existing liquid washer system it’s a pretty complete cleaning solution.
I’m a little too skeptical to recommend it outright, but at the price it may be worth trying with some older records that are going to be junked anyway. In this case, your mileage may really vary.
TechPlay Anti Static Carbon Fiber Record and LP Cleaner
This carbon fiber brush from TechPlay is priced pretty well and comes with a good number of extras that make it a compelling option for the money.
In the kit you’ll find the carbon brush itself, which is meant to clean out the grooves of the record without damaging it in any way. It will also remove the static that increases the amount of dust that makes it into the grooves in the first place. They’ve also thrown in a brush for the stylus (or “needle”) itself. So that covers the two main items that should not have dust on them.
It’s not just dry cleaning brushes either. There’s cleaning solution in the box too.
People who have bought this kit have nothing bad to say about it, so really what have you got to lose?
Record Cleaning Brush Kit, Ultimate LP Vinyl Maintenance Set
While you can find quite a few carbon fiber or carbon fiber-like brushes for not much money, there is something to be said for doing it the right way. As with any product, there’s always a premium version to take a few more of your dollars in exchange for just a bit more quality.
This brush kit from “Record-Happy” comes with much nicer packaging than I usually see, which is a good start.
You get a velvet brush, a carbon fiber brush, a microfiber cloth, and a small amount of cleaning fluid.
The asking price is pretty steep, so this may be something to get for the loving treatment of a few especially valuable or favored records.
The majority of people who have bought this and had something to say about it seem to think that the price is worth it. Whether that’s true for you is only something that you can decide.
Cartel
Otro link
https://wiki.ezvid.com/best-vinyl-record-washers
The 9 Best Vinyl Record Washers
TechPlay Set
9. TechPlay Set
Uncomplicated but effective, the TechPlay Set (appx. $16) helps you remove debris from the grooves of your discs, improving their playing quality and their appearance. Just be ready to complete multiple passes on severely soiled records, as the brush has delicate bristles.
  • Extends life of old records
  • Stylus brush stored inside
  • Cleaner bottle can leak
Studebaker Cleaning System
8. Studebaker Cleaning System
The sleek and stylish-looking Studebaker Cleaning System (about $33) accommodates a variety of disc sizes, making it a versatile solution. It's designed with dual microfiber brushes that clean both sides of a record simultaneously and efficiently.
  • Washable drying cloths included
  • Clear plastic lid
  • Instructions could be better
Boytone LP Cleaner
7. Boytone LP Cleaner
Even if you can’t see the microscopic particles that are negatively affecting the sound quality of your album, you can feel confident that the Boytone LP Cleaner (around $10) is getting rid of them. The handle of the brush rotates, allowing you to easily wash the bristles.
  • Simple and affordable option
  • Firm bristles hold up well
  • Does not come with instructions
6. Vinyl Styl Deep Groove
Sure, the Vinyl Styl Deep Groove (about $55) will remove the dirt, smudges, and stains from your old records, but it will also dry them fully once the scrubbing process is complete. This means you don't have to wait around to start jamming to your tunes.
  • Cleans 7- to 12-inch discs
  • Generous supply of cleaning fluid
  • Tough to pour liquid back in bottle
Knox Kit
5. Knox Kit
You’re looking to clean some discs, not perform surgery, so there’s no reason it should be a complex process. To use the Knox Kit (about $15), simply apply a couple of drops of cleaning fluid to the pad, press it to the album and hold it there for three revolutions of the turntable.
  • Includes a storage pouch
  • Lightweight and compact dust brush
  • Does not emit a chemical smell
Vinyl Vac Wand
4. Vinyl Vac Wand
The Vinyl Vac Wand (around $30) attaches directly to the hose of most standard household vacuums, creating a long, slender channel of suction that can pull debris off the full radius of an album. You can even regulate how powerful the suction is.
  • Durable o-ring for a tight seal
  • Album protection pads included
  • Lifts dust from grooves effectively
Retro Musique Kit
3. Retro Musique Kit
Everything you need to keep your collection playing at its best comes in a handy tin storage container with the Retro Musique Kit (appx. $18). It includes solution; an antistatic, carbon fiber brush for deep cleaning the grooves; as well as a brush for clean styluses.
  • Brush will not damage needles
  • Wet and dry wipes to remove static
  • 30-day returns policy
Record-Happy Premium
2. Record-Happy Premium
Lots of albums have been around for decades, but that doesn’t mean they have to look ancient and battered. With regular use of the Record-Happy Premium (around $30), your LPs will appear and sound significantly younger, and will last for many more years.
  • 2-year satisfaction guarantee
  • Brush made of soft velvet
  • Reduces static charge noticeably
Spin-Clean MK2
1. Spin-Clean MK2
The Spin-Clean MK2 (around $80) comes with everything you need to get an old LP looking and sounding like new again. The large, sturdy washing basin holds full-sized albums with ease, and it includes plenty of fluid for those of you with extensive collections.
  • Includes two drying cloths
  • Rollers operate very smoothly
  • Cleaning takes less than 5 minutes
Editor's Notes
July 06, 2019:
Audiophiles know that the clicks and pops that many associate with vinyl records can be caused by dirt or dust hiding in the grooves. Keep your discs shiny and clean and those distracting noises are greatly reduced, if not eliminated altogether. A vinyl washer, like those you see in our selections, is an essential piece of equipment for anyone who is serious about their record collection.
In this update, we evaluated products based on their effectiveness and value for the price. We added the Retro Musique Kit in one of our top slots because it offers everything you need for a worthwhile price, all packed into a handy storage tin.
The Miraculous Resurgence Of Vinyl Records
Add to that its unparalleled, lossless sound quality, and you have the beginning of a revolution in music collection.
It isn’t often that a technology that has been made smaller and more convenient over time sees an older version of itself revived in the minds of consumers. Classic cars are perhaps one example, particularly because the average Joe can work on their engines without a computer nearby. I know a few poets who like a good typewriter because it forces them to retype their entire poem any time they want to make a change. But you don’t see very many people reaching back for the cell phones that came out in the 1980s, or for cave walls instead of cotton canvases. Yet, the vinyl record is perhaps as vital now as it ever was.
There was a time when it seemed that vinyl would fade out behind the emergence of small, inexpensive cassette tapes and CDs that, when paired with a decent stereo, could create audiophile quality soundscapes. Both media were exceedingly portable, and by the time digital music rolled around, few would have placed their bets on big, unwieldy records.
The problem with digital music, especially in the early days of 56K downloads, is that it suffered from a lot of compression to keep its file sizes at a minimum. Even today, with streaming services flying across cable Wi-Fi networks, the default streaming settings in most apps are about half the file size of songs on an average CD. More than any other part of a mix, the low end tends to suffer from this level of compression, and the explosion of bass-heavy headphones like beats by Dre and others is in part a response to this problem with digital music files.
For the consumer who prefers the in-home listening experience, vinyl records, which were abundant and dirt cheap at garage sales and thrift shops around the country, offered a high-fidelity solution at a fraction of the cost of modern stereo equipment. What’s more, collectors of a certain age began to wax nostalgic for the days when they could hold a piece of art in their hands that was designed to accompany a given musical experience. The tangible quality of vinyl was undeniable. Add to that its unparalleled, lossless sound quality, and you have the beginning of a revolution in music collection.
For many listeners, streaming works just fine for the car or the gym, but many savvy fans understand that this method of consumption provides the artists they love with next to nothing in revenues. Often, you’ll see fans invest in the vinyl of the bands the listen to most on streaming services, both to support the artists and to hear the records they love with a deeper, more complete sound profile.
Perhaps future generations will be so far removed from the concept of physical entertainment media that the vinyl record will eventually see meet its maker. Until then, records serve as a great way to consume your favorite music.
The Different Types Of Vinyl Record Washer
Whether your vinyl records have just accumulated a little too much dust over the years, or they’ve encountered a more hazardous substance, a simple cleaning may be all they need to restore them to their former glory. There are a few different ways to go about cleaning a record, and the diverse options on our list are evidence of that, but with a little consideration, you’ll find the cleaner that’s right for you.
There are also cleaning kits out there that provide you with little more than a brush and some solution, or sometimes a wand that can attach to a vacuum cleaner.
Possibly the biggest divide between cleaners on the market is in whether or not they provide you with their own platform for holding and spinning the record as you clean it. Some units go so far as to create a stage that mechanically spins for you, so all you have to do is hold a provided cleaning utensil in place and let it do its thing. These can be tricky, however, as you don’t have as much control over the rate of spin as you would with a manual cleaning setup. They can also force you to put too much pressure on the record in places where it might not be fully supported, and that might subtly warp the disc.
Other options provide you with a stand in which the vinyl can sit in a vertical orientation. These stands are often equipped with brushes that clean the record as you or a motor spins it around in the stand. Some even utilize liquid cleaning solutions to take the cleaning to the next level.
There are also cleaning kits out there that provide you with little more than a brush and some solution, or sometimes a wand that can attach to a vacuum cleaner. These all necessitate a manual rotation, handheld cleaning, or a cleaning session that takes place right on your turntable.
Cartel
Ultrasonido es lejos lo mejor. Lamentablemente los kits mas baratos están subiendo de precio. Aquí un kit, pero sin la lavadora ultrasonica, que vale alrededor de 150 dólares o quizás menos.  https://www.amazon.com/gp/product/B07TVLY7HS/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
  • Like 2
hace 12 horas, guitarp77 dijo:
Yo tengo la okki nokki, y el resultado es fabuloso.
No es barato, pero se termina pagando sola si es que tienes una colección importante de LPs...
Hola, totalmente de acuerdo, despues de invertir en tener una cadena de audio importante, tener un disco que suene mal por estar sucio arruina toda la experiencia en mi opinión....esa maquina estará disponible en Chile? O la importaste? saludos!
On 10-05-2020 at 13:22, Atracmd dijo:
Con 50k más la lavadora ultrasónica me hice la mia:
hace 5 horas, mr_anderson_cl dijo:
La traje desde EEUU...me debe haber costado unas 480 lucas "puesta acá", hace unos 3 años...se paga sola al final, pero considerando que tengo una colección importante de LPs, entonces le saco el jugo...
LOUD AND HEAVY!
