Nueva línea tope de Polk Audio
Biker
Polk Introduces New Flagship LSiM Home Audio Speaker Lineup
Newly Engineered LSiM Series Features Stunning New Technologies In A Tour-De-Force Performance Of Design And Engineering
BALTIMORE, MD, August 16, 2010 - Polk Audio®, the Speaker Specialists®, today announced a new top of the line home audio speaker lineup that brings the company's legendary sonics to their highest pinnacle yet. The new LSiM series utilizes Polk's most advanced engineering to date, achieving remarkable high-end performance that makes a true audiophile listening experience accessible to music lovers everywhere.
“We're tremendously excited to unveil the new LSiM series, which are the most advanced speakers we've built in our nearly 40 year history, " says Polk’s Vice President of Product Line Management, Mark Suskind. “The LSi line has been Polk’s flagship selection for almost a decade, but in light of current technological possibilities, we felt it was time for a re-visit. The result is not so much an evolution of the current series as it is a re-engineering of the qualities that have made LSi the best in its class."
The new Polk LSiM series encompasses a full range of tower, bookshelf, center and surround channel models, each of which is designed with the finest materials and Polk's most advanced acoustic engineering. The performance objectives for the series were set with an exceptionally high bar -- open, transparent, three-dimensional sound, with accurate tonal and temporal response at all frequencies; extended dynamics; uniformly wide dispersion; deep, tight, integrated bass; and compatibility with a broad range of past, present and future electronics. Each of these difficult sonic objectives has been achieved in the new LSiM series.
The new flagship Polk lineup is spearheaded by two 4-way floor-standing tower models, the LSiM 707 and LSiM 705. Each features state-of-the-art transducers built with Polk's Dynamic Balance® design technology, which combines the latest in composite materials and computer-assisted geometry to create drivers with extraordinarily low distortions and artifacts. Both towers sport a stunning array of these high performance drivers, highlighted by Polk's Dynamic Sonic Engine enclosure, a single molded component that carries both a Polk proprietary 3.25” Extended Linear Motion (ELM) mid-range driver and a 1.0” Advance Isotropic ring radiator (AIR) tweeter.
Combining these transducers in a single optimized array produces an uncommonly wide and uniform dispersion pattern. The top-of-the-line LSiM 707 complements this array with a 6.5" ELM mid-woofer driver and dual 6x9" ELM subwoofers featuring Polk's PowerPort®, which maximizes low-bass energy ordinarily lost as air turbulence in the enclosure. The smaller LSiM 705 features the identical Dynamic Sonic Engine for high frequencies and midrange, along with Polk designed ELM 5.25" mid-woofer and dual 5x7" ELM subwoofers. A bookshelf-sized version of the towers, the LSiM 703, utilizes the same technologies as the towers, minus the internal subwoofer drivers.
Two center channel models are offered in the flagship LSiM series. The larger LSiM 706c features the same AIR ring tweeter and E:M 3.5" mid-bass driver that characterizes the Dynamic Sonic Engine of the larger tower models, flanked by two ELM 6.5" mid-bass drivers with a rear port design. A smaller center channel model, the LSiM 704c features the same layout, only with ELM 5.25" mid-bass drivers. The LSiM 702f/x surround model completes the series for a multichannel setup, offering a ELM 3.25’ mid-range, 2 x 1.0” AIR ring radiator tweeters and a ELM 6.5” mid-woofer driver. All the speakers have been timbre matched for a perfectly blended and balanced acoustic environment.
The Polk LSiM series features Polk's most advanced material engineering, with Super Cell Aerated polypropylene cones that reduce mass and its resulting distortions. Driver baskets are built from cast aluminum frames that provide superior rigidity and exceptionally flat frequency response. Butyl rubber surrounds ensure outstanding linearity through many years of trouble free performance. Finishing touches include magnetic, non-diffracting grills, easy-leveling floor spikes and rubber trims around the driver baskets that create a cosmetically clean fit and finish.
Biker, esos ya estan en el distribuidor local o todavia no
Ni siquiera están en la web, así que me imagino que aún no es oficial el lanzamiento. En todo caso parecen ser el reemplazo de las LSI y no un escalón superior. Se rematan un par de LSI9, jajajaja.
Always workin´
Estan lindos, pero.... ¿Como sonaran? En realidad a mi no me tiran mucho los Polk, pero si me dan bastante curiosidad...
:o se ven muy guapas las torres los woofer ovalados se parecen los de audiocar. Unas cuantas veces probé polk las ultimas fueron unas RTIa5 creo que era ese el modelo acompañado con electrónica onkyo de primera me impresiono el grave que tenían las torres pero a la larga cansaba el sonido además era un poco chillón y los medios los dejaba muy atrás.
ç
Ya mandate un MP jajajajaj solo broma, la caja se cerro este año para el hifi.....mucho derrochhheeee :P
Que rara la cajas le pusieron como todo lo que existe en drivers y además de 4 vías :blink: :
  • Ring Radiator Tweeters, similar al que utilizan las Sonus Faber (sonido tipo italiano)
  • Midrange de 3,5" de aluminio, tipo Visaton (sonido tipo alemán)
  • Midwoofer de 6,5" de aluminio, tipo Visaton (sonido tipo alemán)
  • Woofer dos de 6x9 , Thiel (sonido tipo USA)
No creo que se escuchen mal pero de purista no tienen nada :D :D
Las encuentro algo feas, me gustaban más las Lsi viejas.
Los drivers al menos en los agudos son los mismos que los Lsi viejos.
De todos modos la gama hace rato necesitaba un upgrade.
Lo que puedo asegurar es que no son tube friendly, las viejas estaban muy lejos de ello, no creo que cambie eso ahora.
También tienen cara de KEF...
Espero que hayan mejorado el problema de bajos que tienen las actuales LSi.
ayer en la noche estaba en MW y escuche el nuevo sistema stereo de MARANTZ (PM-7002 y SA-7002; $600.000 c/u) con las LSi 9. Que manera de tirar bajos esos bookshelf... se genera un descontrol FEEEEEO!! Mala, mala mala.
Una vez que me las lleve para el depto y las conecte en serie (para tener 8ohms) y escuchar como sonaban juntas (para puro weviar no mas) NOOOOOOOOOOOO, mal mal mal mal mal. no sirvieron para un sala de 45 mts2.
Se que llegan pronto a Chilito.
Es cosa de gustos no más, el bajo es bien controlado, esas cajas las tengo más de 6 meses. Puede ser problema de salas lo que escuchaste (reverberación excesiva). La prueba que hiciste de conectarlos en serie no sirve, porque probablemente el ampli que usaste no se las puede, hay que ponerles potencia parea que saquen su potencial y además el ampli debiese tener un DF alto para no tener problema de bajos descontrolados. El ideal es un ampli digital.
Always workin´
un bookshelf para una sala de 45 mts2. con reverberacion excesiva.¿?¿? lo dudo.
puede haber sido problema de potencia cuando los conecte en serie, con un ampli de 130 watts por canal y luego con un power dual monoblock de 380 por canal.
es cosa de gusto.. totalmente de acuerdo contigo.
hola
por lo visto la planta de china a mejorado su estetica...pero el sonido de los polk audio esta por los suelos ¿si esta es la linea top of the line, que ha de esperarse de los mas baratos?
polk audio hace mas de 15 años que no le achunta a una caja con un sonido aceptable...
hola
Y a ti quien te auspicia, como para dar este tipo de opiniones tan categóricas?
