AudioLuthier 769 Publicado May 30, 2011 at 22:25 Share Publicado May 30, 2011 at 22:25 El tema de la alta resolución a nivel de acceso casero caa dia cuenta con mas posibilidades al alcance del DIYer arriesgado y con lucas para gastar. "Multichannel asynchronous USB to I2S audio interface delivering 384 kHz 32bit low-jitter bit-perfect performance exaU2I USB to I2S Interface is the missing link between a PC and the I2S input of your DAC. exaDevices USB to I2S Interface is designed for use in high-end DIY audio projects aiming to achieve sonic performance that rivals traditional audiophile grade gear. exaU2I is the first affordable device on the market that makes it possible to stream multichannel 384 kHz and 352.8 kHz DXD audio in full 32 bit resolution from a PC to a DAC with professional mastering quality. Asynchronous operation is achieved by using fast FPGA control core, 256 kB FIFO memory buffer and proprietary ASIO driver. Galvanic isolation of the I2S output from the FPGA core and the USB ground virtually eliminates jitter and common noise originated by the PC. Isolation is achieved by using Giant Magnetoresistive (GMR) Digital Isolators. The barrier capacitance between the board circuits and the I2S outputs is 17 pF. The I2S output is powered by the external DAC power supply and it is completely independent from the USB power supplied to the board. Two precision quartz oscillators allow very accurate clocking with minimum jitter for the 44.1 kHz and 48 kHz sample rate families. Two voltage regulators with low-pass filters provide low-noise power to the FPGA core and the two precision quartz oscillators. This further minimizes jitter and noise. Custom designed ASIO driver provides automatic sampling rate switching and bit-perfect data transfer. The exaU2I USB ASIO driver operates in asynchronous mode and it is completely independent from the Windows sound system WDM / WASAPI support is available by using a third-party native Windows driver - Virtual Audio Cable." http://www.exadevices.com/ Citar "El día del gran debate, cuando llegue la realidad a arbitrar quién estaba en lo cierto, te pasará como hoy: igual que se burlan de tus razones porque estás en minoría se burlarán de tus derechos si no puedes defenderlos de una manera efectiva. Será como en mi novela: el miedo se impondrá a cualquier consideración, y unos por supervivencia y otros por placer, impondrán la ley del “me da igual lo que dijiste. Hoy han cambiado las reglas”. Y será de nuevo la gran purga. La de los inocentes, los ingenuos, y los comeflores." Javier Pérez Enlace al comentario Compartir en otros sitios More sharing options...
joaco_ 4 Publicado May 30, 2011 at 22:53 Share Publicado May 30, 2011 at 22:53 I2S , esa interfaz me encanta , una vez probé un DAC con entrada I2S , pero obviamente no había transporte con salida I2S . Me da la impresión que I2S es la interfaz ideal para la muy alta resolución , pero no se por que la han abandonado tanto . Ahora se ve muy poco DAC con I2S , los que la traen , es muy seguro que sean buenos . Citar im back Enlace al comentario Compartir en otros sitios More sharing options...
amiratos 2 Publicado May 31, 2011 at 02:33 Share Publicado May 31, 2011 at 02:33 Sip, hay pocos y peor aun la lata es que no todos los fabricantes se ponen de acuerdo en como transmitir el la señal I2S, incluso algunos lo hacen via HDMI.... Pocos Transportes, pocos DACs y mas aun no se ponen de acuerdo en la forma de transmistirlo, sin embargo en general parecen ser muy buenos DACs. Citar DISIDENTE Enlace al comentario Compartir en otros sitios More sharing options...
dcolak 2 Publicado May 31, 2011 at 03:54 Share Publicado May 31, 2011 at 03:54 Hm, si uno desea usar PC para poner HiRez musica (en vez de un Squeezebox+DAC por ejemplo) lo mejor seria usar una tarjeta de tipo Asus Xonar Essence STX [img]http://www.hifichile.cl/public/style_emoticons/default/rolleyes.gif[/img] No hay que pensar en USB, I2S, DAC, drivers especiales ni nada de estilo Citar Enlace al comentario Compartir en otros sitios More sharing options...
mariohernandez010 0 Publicado May 31, 2011 at 16:20 Share Publicado May 31, 2011 at 16:20 [quote name='dcolak' date='30 May 2011 - 11:54 PM' timestamp='1306814065' post='63756'] Hm, si uno desea usar PC para poner HiRez musica (en vez de un Squeezebox+DAC por ejemplo) lo mejor seria usar una tarjeta de tipo Asus Xonar Essence STX [img]http://www.hifichile.cl/public/style_emoticons/default/rolleyes.gif[/img] No hay que pensar en USB, I2S, DAC, drivers especiales ni nada de estilo [/quote] ¿y de cuántas lucas hablamos? ¿están en Chile esas tarjetas? (sorry, un no computín a la vista!) Citar Enlace al comentario Compartir en otros sitios More sharing options...
Toperrix 17 Publicado May 31, 2011 at 19:08 Share Publicado May 31, 2011 at 19:08 (editado) [quote name='dcolak' date='30 May 2011 - 11:54 PM' timestamp='1306814065' post='63756'] Hm, si uno desea usar PC para poner HiRez musica (en vez de un Squeezebox+DAC por ejemplo) lo mejor seria usar una tarjeta de tipo Asus Xonar Essence STX [img]http://www.hifichile.cl/public/style_emoticons/default/rolleyes.gif[/img] No hay que pensar en USB, I2S, DAC, drivers especiales ni nada de estilo [/quote] Es lo más práctico, pero contrario al hobby, la gracia es pajearse y armar un tremendo encatrado de cables, Editado May 31, 2011 at 19:13 por Toperrix Citar Always workin´ Enlace al comentario Compartir en otros sitios More sharing options...
dcolak 2 Publicado May 31, 2011 at 19:40 Share Publicado May 31, 2011 at 19:40 [quote name='mariohernandez010' date='31 May 2011 - 12:20 PM' timestamp='1306858801' post='63809'] [quote name='dcolak' date='30 May 2011 - 11:54 PM' timestamp='1306814065' post='63756'] Hm, si uno desea usar PC para poner HiRez musica (en vez de un Squeezebox+DAC por ejemplo) lo mejor seria usar una tarjeta de tipo Asus Xonar Essence STX [img]http://www.hifichile.cl/public/style_emoticons/default/rolleyes.gif[/img] No hay que pensar en USB, I2S, DAC, drivers especiales ni nada de estilo [/quote] ¿y de cuántas lucas hablamos? ¿están en Chile esas tarjetas? (sorry, un no computín a la vista!) [/quote] Los vendian en www.pcfactory.cl Costaban unos cien mil pesos, no se si todavia los tienen en el stock. Yo me compre dos, a una regale a mi hermana Comparado con Cambridge Audio 840C, Asus Xonar Essence STX suena igual o mejor Citar Enlace al comentario Compartir en otros sitios More sharing options...
Patagonia 739 Publicado May 31, 2011 at 19:49 Share Publicado May 31, 2011 at 19:49 ot: Ayer vi en un Multiservice un cable por un lado USB y por el otro 3 RCA (audio y video) por 10 lukas...independiente de la calidad, es llegar y sacar por USB la señal o se requiere algo más??? me pareció muy raro. saludos Citar Enlace al comentario Compartir en otros sitios More sharing options...
pablog 1 Publicado May 31, 2011 at 20:12 Share Publicado May 31, 2011 at 20:12 [quote name='Toperrix' date='31 May 2011 - 03:08 PM' timestamp='1306868883' post='63868'] [quote name='dcolak' date='30 May 2011 - 11:54 PM' timestamp='1306814065' post='63756'] Hm, si uno desea usar PC para poner HiRez musica (en vez de un Squeezebox+DAC por ejemplo) lo mejor seria usar una tarjeta de tipo Asus Xonar Essence STX [img]http://www.hifichile.cl/public/style_emoticons/default/rolleyes.gif[/img] No hay que pensar en USB, I2S, DAC, drivers especiales ni nada de estilo [/quote] Es lo más práctico, pero contrario al hobby, la gracia es pajearse y armar un tremendo encatrado de cables, [/quote] jajajjajaja... Citar Enlace al comentario Compartir en otros sitios More sharing options...
Lagarto 0 Publicado May 31, 2011 at 21:32 Share Publicado May 31, 2011 at 21:32 [quote name='joaco_' date='31 May 2011 - 07:53 AM' timestamp='1306796003' post='63724'] I2S , esa interfaz me encanta , una vez probé un DAC con entrada I2S , pero obviamente no había transporte con salida I2S . Me da la impresión que I2S es la interfaz ideal para la muy alta resolución , pero no se por que la han abandonado tanto . Ahora se ve muy poco DAC con I2S , los que la traen , es muy seguro que sean buenos . [/quote] Hola , parece que ud tiene I2S converter de Lagarto? http://www.single-ended.com/diy-usb-spdifconv.htm este es 24 bit DAC incluido salida de Audio(pero no conectado interno). saludos L a g a r t o Citar Enlace al comentario Compartir en otros sitios More sharing options...
AudioLuthier 769 Publicado June 1, 2011 at 00:14 Autor Share Publicado June 1, 2011 at 00:14 [quote name='dcolak' date='31 May 2011 - 03:40 PM' timestamp='1306870838' post='63874'] Comparado con Cambridge Audio 840C, Asus Xonar Essence STX suena igual o mejor [/quote] Los datos duros para que una apreciación como la suya sea posible: Por alli anda dando vueltas una foto de una tarjeta de audio Onkyo SE200 PCI, esa tarjeta al dia de hoy tiene precio de coleccionista en japon , si la encuentra minimo tendra que desembolsar 400 de los verdes , los componentes de aquella joyita que dio comienzo al mercado de trajetas de audio "high end" Wolfson WM8740 DAC VIA Envy 24HT audio controller Sanyo Oscon caps De alli nacio la idea para crear la Asus Xonar Essence STX con los siguientes componentes: Nichicon Fine Gold caps 3 (legendary) Oscons at strategic locations analog-in section is shielded with an anodized plate to minimize RF DAC chip is the Burr Brown PCM1792 NJM2114Ds for the I/V section [b]The buffer amp is the acclaimed LM4562[/b] este chip es muy bueno lo estoy usando en todas las posicones de mi tarjeta de audio, 3 en total. onboard headphone amp is the TI6120A2 Con todos esto no es raro que de batalla la tarjeta en cuestión..... Citar "El día del gran debate, cuando llegue la realidad a arbitrar quién estaba en lo cierto, te pasará como hoy: igual que se burlan de tus razones porque estás en minoría se burlarán de tus derechos si no puedes defenderlos de una manera efectiva. Será como en mi novela: el miedo se impondrá a cualquier consideración, y unos por supervivencia y otros por placer, impondrán la ley del “me da igual lo que dijiste. Hoy han cambiado las reglas”. Y será de nuevo la gran purga. La de los inocentes, los ingenuos, y los comeflores." Javier Pérez Enlace al comentario Compartir en otros sitios More sharing options...
joaco_ 4 Publicado June 1, 2011 at 02:43 Share Publicado June 1, 2011 at 02:43 (editado) [quote name='Lagarto' date='31 May 2011 - 06:32 PM' timestamp='1306877565' post='63909'] [quote name='joaco_' date='31 May 2011 - 07:53 AM' timestamp='1306796003' post='63724'] I2S , esa interfaz me encanta , una vez probé un DAC con entrada I2S , pero obviamente no había transporte con salida I2S . Me da la impresión que I2S es la interfaz ideal para la muy alta resolución , pero no se por que la han abandonado tanto . Ahora se ve muy poco DAC con I2S , los que la traen , es muy seguro que sean buenos . [/quote] Hola , parece que ud tiene I2S converter de Lagarto? http://www.single-ended.com/diy-usb-spdifconv.htm este es 24 bit DAC incluido salida de Audio(pero no conectado interno). saludos L a g a r t o [/quote] Hola Mr. Lagarto . USB a SPDIF. (By lagarto), lo ocupo desde OSX . [img]http://i55.tinypic.com/9la3ia.jpg[/img] [img]http://i55.tinypic.com/14dgcgj.png[/img] 16bit/48khz . Es muy efectivo para escuchar desde www (radio, y desde las tiendas de música) y se puede ocupar "headphone amplifier" con algún DAC . Editado June 1, 2011 at 02:58 por joaco_ Citar im back Enlace al comentario Compartir en otros sitios More sharing options...
joaco_ 4 Publicado June 1, 2011 at 14:31 Share Publicado June 1, 2011 at 14:31 (editado) [quote name='dcolak' date='31 May 2011 - 12:54 AM' timestamp='1306814065' post='63756'] Hm, si uno desea usar PC para poner HiRez musica (en vez de un Squeezebox+DAC por ejemplo) lo mejor seria usar una tarjeta de tipo Asus Xonar Essence STX [img]http://www.hifichile.cl/public/style_emoticons/default/rolleyes.gif[/img] No hay que pensar en USB, I2S, DAC, drivers especiales ni nada de estilo [/quote] OT; que tal esta ? [img]http://i53.tinypic.com/dfhun8.jpg[/img] Todos los chips "highend" de AKM , 142dB SNR , hace una par de meses la tengo pero aún no la pruebo . AES/EBU . sólo es "digital router" , no tiene opamps ni DAC , jitter correction y "generador de frecuencia de reloj" con entrada de reloj y sincronizar otros relojes ... [img]http://i52.tinypic.com/dmb70w.jpg[/img] Y se puede fabricar un cable AES de los metros que sean necesarios para una estación de audio digital . Editado June 1, 2011 at 15:16 por joaco_ Citar im back Enlace al comentario Compartir en otros sitios More sharing options...
guax 179 Publicado June 1, 2011 at 15:14 Share Publicado June 1, 2011 at 15:14 [quote name='joaco_' date='01 June 2011 - 10:31 AM' timestamp='1306938664' post='64003'] hace una par de meses la tengo pero aún no la pruebo [/quote] Quizas suena como las pelotas y no te has enterado Citar We all complete. Maybe none of us really understand what we've lived through, or feel we've had enough time. Enlace al comentario Compartir en otros sitios More sharing options...
joaco_ 4 Publicado June 2, 2011 at 02:13 Share Publicado June 2, 2011 at 02:13 [quote name='guax' date='01 June 2011 - 12:14 PM' timestamp='1306941282' post='64018'] [quote name='joaco_' date='01 June 2011 - 10:31 AM' timestamp='1306938664' post='64003'] hace una par de meses la tengo pero aún no la pruebo [/quote] Quizas suena como las pelotas y no te has enterado [/quote] espero que no , porque me metí de lleno en el tema de la estación , por eso no la he probado . Citar im back Enlace al comentario Compartir en otros sitios More sharing options...
